manually lock torque converter?
IS there a way to lock the torque converter for dynoing without a reprogrammer? In the buick turbos we just used a paper clip to jump two terminals in the ALDL terminal.
Thanks
Thanks
Yes there is. You need to find the right wire on the pcm and tap into it. Run that wire to one side of the switch and a ground to the other side of the switch and you can lock it whenever you want manually.
Dan
Dan
