What tire pressure on the street/track - on stock tires
Old 07-06-2006, 06:13 PM
FireSilverLullaby's Avatar
Default What tire pressure on the street/track - on stock tires
Hey I was just wondering What tire pressure you run at the street and the track on stock tires. I have 38lb in the front and 30 in the back. My manuyal says to keep all tires inflated to max psi for High speeds but I want alot of traction, and high speeds.
For the track people have told me to drop them to 20 or lower. What works best for you guys with stock or street tires. And will it help to inflate the front tires to max psi?
Old 07-06-2006, 07:26 PM
Hambone 7's Avatar
max psi is written on the side of the tire. it differs from brand to brand and what the tire was designed to do. No way in hell would myself persoally deflate a radial street tire to >20 psi.
Old 07-07-2006, 01:58 PM
Dal1as's Avatar
Like was said it depends on the tire but definately do not deflate your rear tires. Radials will cup and actually decrease your traction. On average you can probably keep them around 30 psi in the rear and air the fronts to the max pressure.
Old 07-07-2006, 05:06 PM
Alright thanks that makes a lot of sense. I think ill just keep my rear wheels at 30 and raise my front tires to 42 to 44.
Old 07-07-2006, 09:58 PM
Dal1as's Avatar
Just remember to only keep the fronts like that at the track. Otherwise you'll have all sors of issues on the street.
Old 07-09-2006, 08:42 PM
what kind of issies cause their at 38 right now when im driving on the street, it says max 44. And the manual says to fill them to 38 for high speed driving.
Old 07-10-2006, 04:28 PM
dailydriver's Avatar
With those front pressures, if you are not hitting the turns really hard, you will wear out the centers fairly quickly (depending on the compound/treadwear ratings), given stock spec alignment.
Old 07-10-2006, 08:17 PM
98SuperSport's Avatar
i think 33, 34 is good for all 4 tires for the street. harder up front and softer out back for the track, like 40 and 22psi
Old 07-10-2006, 10:41 PM
Dal1as's Avatar
If you have the 17 inch stock wheels that seems a bit high. With a lot of trial and error I run my tires at 33 front 31 rear. No it depends on the tire and the sidewall but I wouldn't devitate from that much. 22 psi in a street tire is way too low. Even at the track.
Don't do major burnouts on street tires either. It will glaze them and actually make traction worse.
Old 07-11-2006, 05:10 PM
Arlright I think im gonna go with 34/32
