BadAzz96Z28
07-07-2006, 10:42 AM
I have a walbro 255 inline pump w/stock intank pump and need some advice on this. When I installed the inline 2 years ago I did what was recommended by a sponsor here and tied the pump into the wire harness that feeds the stock pump as well.
My concern is that with this setup at idle I am at 50psi and WOT it runs around 42psi. Could this be b/c of the way it is wired up and not getting enough voltage to feed the 2 pumps on the stock wires? If so I guess that it would be good to run a seperate circuit for the inline pump and see if I get my fuel pressure back up a bit.
How much would getting the fuel pressure back up change the car as far as AFR, power, fuel inj. duty cycle? Im just wondering now b/c I am finished with my TNT nitrous kit and if n/a pressure dips to 42psi then it will drop more on the spray.
AFR with the current set-up is 13.0 and injector duty cycle is at 94%
Thanks for the advice in advance and sorry for the long post
