Thinkin about a cam w/ stock headers
Old 07-07-2006, 07:47 PM
tripps's Avatar
Default Thinkin about a cam w/ stock headers
I need to replace my valve springs, so I was thinkin that I might as well replace the lifters and get a cam. What kind of cam would make the best power and be the best option when i'm still running stock headers?
Old 07-07-2006, 08:02 PM
erikthegoalie's Avatar
do you mean headers or heads....just wondering...
Old 07-07-2006, 08:17 PM
1sicws6's Avatar
i would think thunder racings cheatr cam
Old 07-07-2006, 09:10 PM
tripps's Avatar
unfortunately i mean stock headers.
Old 07-07-2006, 09:55 PM
radz's Avatar
cheatr cam for sure it was deigned to run with stock manifold
Old 07-08-2006, 10:06 AM
KCS
Moderator
KCS's Avatar
With your stock manifolds, overlap is not your friend.
Old 07-08-2006, 11:00 AM
tripps's Avatar
What do you mean by that? What else should I probably replace while im doing the cam swap? Car has 100k miles on it, same with engine.
Old 07-08-2006, 11:40 AM
z28misfit's Avatar
I would consider a timing chain and possibly an oil pump becuase i hear the oil pumps are known to go without warning.
Old 07-08-2006, 12:16 PM
dnm12's Avatar
yes here is what you do with a car with a 100K mine has LT's though
-224/224 Cam with Lobe Separation Angle=114º
-PRC Dual Springs
-Hardened chromoloy pushrods
-Titanium retainers
-Hardened Seats
-LS6 ported oil pump
-Rollmaster single roller non-adjustable timing chain
-Gasket kit
-O-ring for oil pump
-More Tool
Old 07-08-2006, 12:22 PM
Import Patrol
CrawlinWS6's Avatar
I would suggest putting some headers on their anyway. Even if you go with midlenghts. You can pick some up for a good price in the for sale section here.
