Patriot Performance LS6 heads 59cc HELP
Ls6 heads are #243 castings, patriot "ls6 style" heads start out as #035 bare gm lq9 castings.
From patriots website
LS6 Style Chamber Only Heads:
035 OEM castings
Welded Chambers
Heat treated & machined
CNC Chambers only
Milled to OEM deck height
Bronzes Guides installed
Hardened seats installed
Chamber choices:59,64,68,72
No core required
035 OEM castings
Welded Chambers
CNC Chambers only
No core required
Originally Posted by c5_ls1_6spd
will these 59cc heads & 2.02/1.57 valves work with my MS3 114LSA cam?
I'll be using stock GM head gaskets.
If you put 2.00/1.55 valves in there then it will fit if heads unmilled.
Originally Posted by jz06man
They will fit ..... I have a similar cam with the same heads... No issues here...
Similar don't mean squat anyways. Duration and valve events is what determine if a cam will fit certain heads.
EXPL: 64 cc 5.3L, unmilled with stock gasket (2.04 int/1.57ext)
232/234 112 will not fit but 232/234 113+0 will
