Why you shouldn't run the stock rockers...
Old 07-09-2006, 12:50 PM
7 Second Club
Phil99vette's Avatar
Default Why you shouldn't run the stock rockers...
We decided to retune our 00 automatic 346/ET 11 degree car this morning. We recently added LG pro long tubes and the car felt like it needed some more fuel and it sure did. The morning started fine, idle tuning went very very easy with the RTT tuning, took about 10 minutes to get the fuel dialed in @ idle. Inital driving impressions were correct, we had to add 3-7% fuel almost everywhere in part throttle, WOT was pretty close. The cruise was going great, did a pull to 6500 2nd and 3rd and the engine started tapping. The tapping was remenicent of 2 years ago when I floated the valves. Babied the car back to the house and used a makeshift stethoscope and found the noise was on the passenger side. Pulled the valve cover and found this....
Old 07-09-2006, 12:54 PM
ShevrolayZ28's Avatar
Yikes! Are you running a big cam with super-strong springs?
Raise's Avatar
seen plenty of stock rockers handle monster hp. not sure why that happened. that sucks man
Old 07-09-2006, 03:02 PM
98SS1LWEE's Avatar
Yeah, that' sucks. Let me know what setup you got, cause i jsut installed hardened pushrods and had no intentions on spending another four hundred or so for rockers, but if you're not running a huge cam, then i am scared not to get rockers. Also, stronger springs than 918's?
Old 07-09-2006, 03:20 PM
7 Second Club
Comp Cams 238/244 XER
977 springs
Old 07-09-2006, 03:22 PM
PREDATOR-Z's Avatar
That is unusual to break like that. Bearing spill is the regular culprit.
Old 07-09-2006, 03:48 PM
Grimes's Avatar
weird....casting flaw?
Old 07-09-2006, 04:13 PM
67Firebird455's Avatar
Yeah, or a good quality hardened pushrod (thickwall) that are too long, and a nicely tightened rocker would do that...
Old 07-09-2006, 05:31 PM
HottLS1Z's Avatar
I have a 98 with a stock valve train that I have the rev limiter set at 6550 it shifts at 6300....car has 129K on it never a problem with any rockers....thats wierd...my 00 shifts at 6800 with 918 springs and again stock rockers no problems yet.....knock on wood...
Old 07-09-2006, 06:25 PM
What's a Sticky?
97MysticZ's Avatar
That is weird. At least you were smart about it and got it home and found the problem quickly.
Old 07-09-2006, 07:33 PM
spazzyfry123's Avatar
That really sucks man. Even though that is a good sized cam, I am still confused as to why it snapped? Never really seen that before.
Old 07-09-2006, 09:03 PM
Phil'sC5vette's Avatar
sorry about the rocker phil.
Old 07-09-2006, 09:12 PM
bad6as's Avatar
another reason aprox 85k
Old 07-09-2006, 09:21 PM
Mr. Luos's Avatar
Currently running stock rockers in my 402.
Spins to 6700.
Cam is a 248/254 629/622 113.
No problems. No noise, no bearings. They have 31K on them.
I will most likely have them re-built soon though.
Old 07-09-2006, 09:36 PM
Raise's Avatar
damn phil that sucks. is your geometry on point? heads milled/cam base circle size/pushrod length??
Old 07-09-2006, 09:46 PM
DocEwww's Avatar
Ive had good luck with mine also to 110K miles but I just picked up some Harland Sharps for insurance. Ive never seen them break like that tho.
Old 07-09-2006, 10:04 PM
I can't even figure out what that is...
Old 07-09-2006, 10:10 PM
bad6as's Avatar
neeedel bearings total of 66 per rocker
i had 33 floating around and i dident know it till i went to change the oil
Old 07-09-2006, 10:22 PM
Louis's Avatar
We run stock rockers on the World Challenge car. 7400 every shift, 4000+ race miles, no issues.
Did I mention, there were a few 9200 and 9400 miss shifts in there as well? Just something that happens with race cars.
Old 07-09-2006, 10:59 PM
Ferocity02's Avatar
Originally Posted by Phil99vette
...used a makeshift stethoscope and found the noise was on the passenger side.
Two soup cans and a piece of string? We all have our homemade tools
