a/c doesnt blow any air after cam installation?
I did a cam swap/LS6 heads and i didnt remove the a/c or anything, why does it not blow any air? I have a torquer V2 112+2 is it true it might not being able to pull enough vacuum b/c of the bigger cam??
Originally Posted by Shinerbock07
does that have to do with being stuck on
defroster mode
defroster mode
TT-TECH Veteran
Look everyone is telling you what the most likely cause is and I agree it is that vacum line I will bet money on it you are missing it somewhere Travis. The A/C controller is a guess from you, but look at what you just messed with and you will have to agree it would be a fluke if it acctually went out at that exact moment also? Good luck! I'll take a look at it if you can't find it.
You're saying you "believe" that line is for "engine control" yet there's several folks here who *know 100%* EXACTLY where that line goes.. Go back over the posts in here -- that line runs from the intake, to a vacuum tee, small inline filter, and ultimately inside the car to the A/C controls. Without a steady supply of vacuum, you're stuck in defrost. Check all the vacuum lines and connections (there's not too many) and you'll find one broken/disconnected.
I have the same problem. For the line starting from the back of the intake, do you have to unbolt the intake and tear it apart to get to it? Or can this all be done with engine intact?
EDIT: I ordered the tubing I needed and found out where I am going to have to install it. I just can not see behind the intake so I do not know if I will be able to reach it with no problems. Another thing, could this vacuum leak be causing performance issues such as the engine bogging bad for about 5 minutes from start?
TT-TECH Veteran
I already pluged the vacuum line back in the MAP sensor but I believe thats for engine control but i could be wrong..well im going to GForce for a tune on monday so if you want me to come buy give you the 20 bucks i owe you and maybe u can figure it out if i havent already figured it out by then.
Jeff
