hood shocks ?
hood shocks ?
hey any body out there run into a problem with fiberglass hoods. The stock lifts are to tight. I was just going to build a prop rod (but if any one has some sugg.) those lifts would look alot better!
https://ls1tech.com/forums/appearance-detailing/471781-fiberglass-hoods-hood-struts.html
Right now, I'm using the old stock ones. You can either look for some used ones that don't have a lot of pressure like brand new ones do, or do something like a guy did in that thread. I've seen aftermarket fiberglass hood struts, but I don't recall seeing them for 4th gen F-bodies. But I can't say I've looked very hard yet.
I made a bad mistake on mine. The guy I bought it from said to only use 1 hood shock since they're so strong....so I took my drivers side shock off. Now the hood near my headlight on the passengerside is warped pretty bad and it looks ilke my hood is open from the side
