what size pushrods?
It depends if your heads are milled or not and what gasket thickness you are using.
In stock head height and stock gasket application you can use 7.425 for added preload and reduced valvetrain noise.
Originally Posted by Mr. Luos
What is the stock preload on the stock lifters with a completely stock set-up??
Yeah...stock.
Yeah...stock.
1999.
Since we are here, what is the base circle of the stock cam?
I would also like to know....
Have a Tr224 and am running Tr 7.4" pushrods.
I wonder if I need longer ones.car is pretty noisy.
