ATI crank pulley and ASP overdrive alt pulley?
my ATI crank pulley is a 6.75. I dont know if this is considered an underdrive pulley or factory size. It was part of a kit i got from EPP but I dont know if its ok to run with the ASP overdrive alt pulley. I went ahead and purchased a belt that fits. Im just not sure if i can use the two pulleys together or will it work the alternator too much. car is not a daily driver and I am running two amps so im thinking ill need the overdrive alt pulley anyways....
