how much compression?
how much compression can you run with a fi setup. im looking at 9.7:1 static and 8.0 dynamic. once you factor boost into this, it gets really high really quick. how high can i go? im looking at 14.98:1 on 8 psi. thanks -Dave
With ATI ProCharger centrifical superchargers, we set the compression ratio in the 9.0 to 9.5/1 range. With a front mount intercooler with the above combination we can run 16 psi on 93 octane pump gas. Bob
