! side door molding
Old 07-10-2006, 04:21 PM
FireBreathingChicken's Avatar
Default ! side door molding
Does anyone have any tips for removing the side door molding (on the outside) ? Do you just pull it off or what? Also is there a product I should use to remove the glue? (goo gone or goof off?) Thanks
Old 07-10-2006, 04:41 PM
Brian2006's Avatar
I just ripped mine off and rubbed the glue off with my thumb. Others like to heat it up with a heat gun of some sort that way the glue comes off a little easier and you'll have less blisters on your thumb.
Old 07-10-2006, 05:03 PM
dj2005's Avatar
Yep thats what I did except I used a plastic thing much like a credit card. Very easy to take off.
Old 07-10-2006, 06:04 PM
nasty99WS6's Avatar
I just took the back of a hammer, you know, the prongs, and dug in. then the glue that was left, I sanded off with 80 grit sandpaper. then I globbed a bunch of black touchup paint on it. wala.
Old 07-10-2006, 06:35 PM
Ling_650vette's Avatar
Heat gun it, then grab some fishing line/denal floss and run it behind the piece.
Then get some goo gone and viola.
Old 07-10-2006, 06:38 PM
nasty99WS6's Avatar
I guess thats another method..
Old 07-10-2006, 06:41 PM
ZROCWS6's Avatar
You used a claw hammer?!
Old 07-10-2006, 07:07 PM
SLVR_99-Z's Avatar
i'm pretty sure that it was sarcastic. he also said he sanded the glue off with 80 grit paper and then globbed on touch up paint.
Old 07-10-2006, 07:50 PM
Camaro Rick's Avatar
Hmm. Interesting... Does anyone have any pics of camaros with !moldings?
Old 07-11-2006, 05:28 AM
nasty99WS6's Avatar
tons of pics...SEARCH.
You would be correct.
Hot 90 degree day, pulled off slowly by HAND, then rubbed the remaining glue off with my finger, little polish, little wax, and bye bye molding.
Old 07-11-2006, 05:52 AM
old and good's Avatar
i pulled mine of in cold weather, if the glue stays on the molding then its easyer to remove. then i just took some break cleaner and wiped the leftovers off. i also haveg pictures in my Picture thread
Old 07-11-2006, 06:37 AM
nikeair042's Avatar
pray...
so many people have problems when they take it off they strip the paint, or there is a different shade of color under there...personally i think its stupid, cause the moldin is there for a reason....one of the reasons is parking, so when stupid ***'s fling their door open into yours, the molding prevents dents. unless its an SUV then it just annhilates you door lol...but whatever floats your boat...
Old 07-11-2006, 08:11 AM
Smoke Panther's Avatar
FOR THE LOVE OF GOD, check to make sure that your moldings weren't painted AFTER they were put on the car
Old 07-11-2006, 08:34 AM
NightWindDriftr's Avatar
Wasn't that you who did this? That sucks bro.
Old 07-11-2006, 11:05 AM
farnoush's Avatar
When taking the moldings off pull straight up and back. It makes most of the glue stay on the side moldings. I used this method and took mine off in 10 minutes.
Old 07-11-2006, 12:15 PM
Hmmm....a lot of useful and interesting information on this. Especially the hammer. I think ill use a sledge hammer I have and wedge an ice chisel under the modling and give it a good whacccccccccck!!!!!
Old 07-11-2006, 12:18 PM
freakynipples69's Avatar
That's how I plan to remove mine. Seems to be the easiest way.
Old 07-11-2006, 12:19 PM
DroppedM6Z's Avatar
unless the car has been repainted, the body color is under every piece. I removed mine about a year ago....some wax and grease remover should take the glue off
Old 07-11-2006, 01:55 PM
the sun makes the color often get a lighter shade and the molding keeps the paint under it darker so when you remove the molding the color can be different but thats no biggie it can be buffed out without a prob.
concerning the molding as a protection device it seems that the doors on other cars always seem to hit my car in other places than the protective moldings
Quick Reply: ! side door molding
