Truck Oil filter ???
Old 07-10-2006, 04:33 PM
SS DNA's Avatar
Cool Truck Oil filter ???
Is it PF61 from AC Delco ????
Thats what I bought but I want to make sure it is....
Thanks!
Old 07-10-2006, 04:54 PM
GMTECH2's Avatar
PF46 is our filter
Old 07-10-2006, 05:38 PM
JHZ28's Avatar
pf 61 will work. same as 46 just longer
Old 07-10-2006, 06:58 PM
NHRAMAN's Avatar
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
is this the same as on ls1...just longer u mean ???? if it is not listed for ls1 why use it?????????
Old 07-10-2006, 07:10 PM
00454sscamaro's Avatar
.... i used to use a van style for my 84 camaro oil seemed to stay cleaner longer. why not use it if its the same thread/ daimeter etc. who cares if it says its for ls1 or not if its only difference is how long it is.
Old 07-10-2006, 07:13 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
The biggest/longest one you can find will generally work better in your favor. You just have to make sure you don't leave it on a speed bump.
Old 07-10-2006, 07:33 PM
iamsickofitall's Avatar
the PF61 is fine...i run that on my car...no clearance issues and i just dump all 6 quarts in instead of 5.5 or 5.75 or whatever it's supposed to be with the smaller filter
Old 07-10-2006, 11:25 PM
That's what she said...
TheBlurLS1's Avatar
I run the K&N 2006 which is the truck filter, no problems from it and I noticed a boost in pressure over the crappy Frams I used to run. The oilfilter is the first thing the oil hits after the pump, so a larger one will offer more flow and help boost the pressure for the rest of the stuff on down the line.
Old 07-11-2006, 01:35 AM
HD1911's Avatar
the PF46 is a wee little lad...i like the mobile 1 m-206
Old 07-11-2006, 02:28 AM
SS DNA's Avatar
Thanks guys!!!
I put the PF61 today!
No clearance issues here
Old 07-11-2006, 08:57 AM
01 Red WS6's Avatar
If you are hitting the longer oil filter on a speed bump then you will hit the oil pan on it as well. You're screwed if that happens regardless
Old 07-11-2006, 10:15 AM
yeah the filter only hangs like .5" lower than the oil pan
Old 07-12-2006, 04:50 PM
98camaroLS1M6's Avatar
Yeah, you'll hit other things before you hit that, like the kmember.
