Picked up a P/P TB, opinions? *pictures*
That's what she said...
Yes you can replace the blade. What year is your car and what year did this TB come from? You might need to swap out the shafts/cam on the TB's as well. If you're not sure what year car it came from, swap the shafts anyway.
Make sure to use some blue loctite on the screws when re-installing the blade.
bene, what tools did you use to knife the blade like that? would there be other downsides to leaving the current blade other than higher idle lower mpg? and would there be any benefits?
also guys, does anyone know what the stock inner diameter of that hole is? i'll measure the ported tb with a caliper and see what it comes up.. how severly would this affect idle? in terms of rpm
