How to clean maf sensor ????
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Originally Posted by 8GTOKLR
brake cleaner should work. it evaps too
That's what she said...
When you clean the K&N, only oil the side that points down when the filter is installed. The air passing through will pull the oil into the filter. If you oil the top (lid side), it's more likely to fly off and land in your MAF. I've been running my K&N for about 2.5 years with no problems.
PS - After you wash the filter out, leave it sitting ontop of the a/c condensing unit outside your house so that warm air will blow through it. It will be bone dry in about 10-15 minutes.
I normally use electrical contact cleaner. This is a newer MAf cleaning product by CRC industries:
http://www.crcindustries.com/auto/co...x?PN=05110&S=Y
I am going to check out local parts store for that. I used CRC brake cleaner. Good info Carbide
I used the QD Electric cleaner from AutoZone on mine it just sprayed it on and it cleaned all the gunk off. Car actually ran better after I cleaned it also lol which is always a plus
