Check Engine light on b/c of AIR. Reinstalled, won't go away??
Just like the title says. I put the AIR back on, reset the computer (disconnected the battery for 5 min.) and turned it back on and it was still there. Any suggestions on how to get this to go away?
Not sure if just disconnecting the battery for 5 min alone without pulling the fuses with the ignition on will competely reset the PCM, what code(s) you throwing?
I know it is the AIR b/c that was my only mod to the car and the light came on right after removal.
PCM Reset:
Turn key on, don't start car
Pull PCM BATT and PCM IGN fuses in engine compartment
Wait 5-10 min
Turn ignition off
Replace fuses
If the light comes back on autozone will read it free.
Wait 5-10 min
Turn ignition off
Replace fuses
PCM Reset:
Wait 5-10 min
Turn ignition off
Replace fuses
Wait 5-10 min
Turn ignition off
Replace fuses
