ultraz
07-11-2006, 11:07 PM
Ok, so
I was on my way to work when the dash lights all come on at once and the car starts buzzing at me like when you turn the key forward before you crank the engine. The engine had died so i pulled over and could hear it cranking but it would not catch.
I shot carb cleaner through the intake and it starts right up. SO then im thinking its the fuel pump. I had the car towed home then checked the fuel rail and it says 50 lbs which is right around where I think it should be. I put an injector light on it and it does not light up when i crank it SOOO.
I tested the wires and the 12v one is fine, while the other does not show a ground. WHAT IS MY PROBLEM?
