MAP senesor and FAST 90
Just wanted to know if I should leave the MAP sensor stuck in the FAST 90 without any clips or anything...
My LS2 intake had a clip... but the FAST 90 has nothing but a hole...
What do you guys do? Think it will be fine?
Too bad the FAST makes good power, it's not really thought out that well as far as some of the accessories go. No provision for anchoring the EVAP solenoid, the EVAP tube is at the wrong angle, and the MAP sensor not only fit's poorly, there is no secure way to mount it.
I got some sensor safe RTV and put the sensor in, put it at the correct angle, and 'glued'it in place with the RTV from underneath. Of course you have to take it apart to do that, and that can potentially open up a whole new can of worms.
You may be able to use RTV to fasten it from the top though. I know I felt I had to, mine was kind of flopping around in there.
