Will My Paint Get Damaged If
use something like scratch x on it too much? or any abbrassive for that matter? i keep reading that u need to break down such products so they sand or smooth out the clear coat...so does that mean that after a while of doing this thee clear cpat can be removed or damaged i guess?
You can go through the clear coat if you're using a really abrasive polish and do it often by machine. By hand it would take you quite a while unless you hit an edge often that could wear through quicker. If you're talking wet sanding to get rid of the factory orange peel then you do need to be careful because you can sand through the clear.
