Turbo Guys: What Cams Are You Running?
I'm thinking of buying a Comp cam that specs out at 581/588 224/228 @50 on a 114+4 LSA. This would be a great N/A or Nitrous cam but I'm concerned about it with a turbo. I'm going to be running a T6 flange T76 turbo with a 1.08 AR and shorty headers. I know that each and every cam on a turbo setup is different and should be speced according to the entire package. My thinking is that with shorty headers and being a T6 flange with a 1.08 AR the standard split cam should help spool the turbo and not hurt backpressure at all. I should have more than enough flow to accomidate this cam. However, I'm concerned about the advance built into the cam. The 114 LSA is fine but being a 114+4 that would put it on a 110 ICL. My understanding is that a 110 ICL would cause cylinder pressure to rise and increase my DCR. I'll be running stock heads for a while. Eventually going to go with #317's.
What cams are you guys running with what turbo setups?
Also what are your thoughts on this cam or running a standard split with my setup?
it seems like the reverse splits would matter more on engines with high backpressure?
I wonder how many people actually measure their backpressure.
unless you're copying a proven setup you can only hope to get it close
usually close is good enough
I'm more so worried about the +4 advance built into the cam that would put it on a 110 ICL. Wouldn't this raise cylinder pressure and compression too high to use stock heads? If so, couldn't I just degree the cam or use an adjustable timing chain to retard the cam to 114 LSA 114 ICL straight up?
