Stereo & Electronics - Driver Side Window doesn't work Passenger side is fine after clutch install
kapedogg
07-13-2006, 07:25 AM
My car has been sitting on jacks for a month now waiting for my clutch to come in. Finally got around to the doing the install last night, and the battery was dead. We jumped it, then tried rolling the windows down to listen to everything and the Driver side window doesn't move at all, like it's not getting any power. The passenger side window works normally though. WTF could have happened while it was just sitting there. I'll check fuses when I get home from work, it was too late last night to do it.
Also, I have a viper alarm that can roll the windows down and tried using that, but only the passenger side would go.
shouldaboughttheZ
07-13-2006, 08:28 AM
The window motors are notorious for going out.
kapedogg
07-13-2006, 08:32 AM
The motors are only about 6 months old and everything was perfect when I parked the car in the shop a month ago, so I know it can't be that. I'm guessing something electrical, maybe from jumping it with a big charger/jumper unit on wheels my grandpa has.
shouldaboughttheZ
07-13-2006, 08:34 AM
pull out the voltmeter and start checking the connections on the back of the switch
kapedogg
07-13-2006, 09:36 AM
That's the plan, but I don't exactly know what I'm looking for. I just thought it was odd that it works one day, the car sits for a month, then doesn't work, plus I assume that the two windows share a lot of wiring, so there would be an easy explanation. I was wondering if someone might have a quick thought on what may have happened, or been through this before, or advice like "hey it's probably this cause of this, so check this real quick"
kapedogg
07-13-2006, 01:28 PM
I went home at lunch, it still didn't work, I tried it a couple more times, and suddenly it works just fine. Normal speed, no stopping and starting, just perfectly smooth operation like when I parked it a month ago. I'll post updates if it comes back and I figure out what/if anything is wrong with it. Thanks as always guys
kapedogg
07-25-2006, 02:15 PM
So, I just got back from a 1 week vacation and the driver side isn't working again! I hope it will magically fix itself like last time. Any advice guys?
Charlie Hustle
07-25-2006, 05:53 PM
as soon as you find something out let me know too....i have the exact same fucking problem. the weird thing is that the driver side motor was just recently replaced. the passenger side still works fine. i checked the fuse, and it seems to be fine. anyone else have any suggestions? :bang:
bzaudio
07-26-2006, 01:04 PM
I had the same problem and found out that all it was the motor plug wasn't all the way plugged in. happened when i took the door panel off the plug got pulled a little tight. check that out at the window motor itself.
kapedogg
07-29-2006, 02:26 PM
Checked all wiring connections, seem fine, fuse seems fine, I guess I'll have to try a new motor but this one is only a year old at most and had no signs of slowing down or going out.
What I did find was that when I clicked the driver side window down button the motor would make an electrical clicking sound then a 3"x4"x2" black box under the dash in the middle of the car that was in a plastic "holster". Someone told me it was the express down relay(Following number sets were on it 62186, 52615, 12182126, EPIC2797). Could this be the problem? Or is it supposed to do it. I suppose I'll get a new motor today, plug it in and see if that one operates. One more note, I had a Viper 791XV installed with a DHT 530T Module as well. The viper remote does work the passenger side still and worked for those few days the driver side worked before my vacation. Anyway, the remote gets the exact same reaction as the switch in the door
kapedogg
08-06-2006, 08:56 PM
Replaced the motor today, and all is well. Can't believe it went bad while the car sat for a month!
