Suspension & Brakes - $100 cash to anyone who can tell me WTF this noise/vibration is.....
Quickin
08-25-2002, 12:27 AM
Here's all I can tell you.....
When I'm on the highway doing 60+ mph and I'm driving perfectly straight everything is fine except that my steering wheel is a TINY bit to the left, it's not perfectly centered. The car is alligned and drives perfectly straight on all roads. Then, when I casually turn the wheel to the right to change lanes I get a grinding noise and I can feel it with my feet. ZERO vibration in the steering wheel, just at my feet. When I turn the wheel to the left to change lanes, smooth as silk.
My brakes: I just got rid of my factory rotors (67,000 miles) and it's been doing this for the last 13,000 or so. My left front rotor was warped and I thought that was the problem. Last week I installed my new Eradispeeds, hoping it was the warp. But it's still there. The new rotor looks fine, no uneven wear yet when compared to the right rotor.
At speeds below about 55-60 it's not there at all, but the steering wheel is a tad to the left.
Now, when I did the rotor change, the left front brake pad was digging into the rotor about 1 full inch in from the outer edge. It appears that the brake pad wore in that area faster than all the other pads. I assume it did that because of the warp constantly rubbing it all the time, evan when not braking and just rolling to a stop i could hear it rub every time it made a revolution. All the other rotors and pads were just fine.
Any ideas???? I would hate to be ruining my new Erad rotor. Maybe the caliper and/or bracket is bent?????
I'm going to have it checked on Monday to see if it's a bent caliper or bracket.
I'll check whatever you all tell me to, whoever figures it out, I promise $100.
ZULater01
08-25-2002, 12:47 AM
Have you checked your brake lines to make sure there aren't any tangled or rubbing on anything . That could cause it b/c if you turn it one way it wouldn't catch but the other it would and that could cause it. Just a thought. Do you have any aftermarket front suspendion parts or springs?
Quickin
08-25-2002, 02:00 AM
[QUOTE]Originally posted by ZULater01:
[QB]Have you checked your brake lines to make sure there aren't any tangled or rubbing on anything . That could cause it b/c if you turn it one way it wouldn't catch but the other it would and that could cause it. Just a thought. Do you have any aftermarket front suspendion parts or springs?
_________________________________________________
I am 100% factory stock. I had a brake job in May and everything was in order. Then last week my Erads were installed, the guy checked everything for me, it's all good.
ZULater01
08-25-2002, 02:50 AM
I have no clue then. Take it up to a dealership and they'll check it out for ya prob. I hope you find whats wrong with it.
DARK AGE 53
08-25-2002, 08:09 PM
I'm going to go in a different direction then everyone else is, do you have headers....if you do it might be the steering shaft rubbing against the headers.
Al
BYE RICE
08-25-2002, 08:28 PM
The last time my car made a sound like that It was a bad wheel bearing(replaced under warranty).
TUFFLS1
08-25-2002, 08:43 PM
It sounds like a left front wheel bearing because when you turn to the right you put the weight on the left front wheel bearing sometimes you <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" /> need pressure on it let me know i like to help solve problems
TUFFLS1
08-25-2002, 08:45 PM
It sounds like a left front wheel bearing because when you turn to the right you put the weight on the left front wheel bearing sometimes you need pressure on it. let me know i like to help solve problems
2000 Camaro SS
08-25-2002, 08:50 PM
my vote is the wheel bearing also.
TUFFLS1
08-25-2002, 10:11 PM
if you dont want to spend the money on a wheel bearing switch them from left to right and see if the noise changes hub&bearings are not cheap
wrencher
08-26-2002, 12:29 AM
Have your front end checked out. Is it more of a rapid repeating noise? You may have a loose or damaged inner or outer tie rod. Could also be a bad rack mount or even a bll joint, either way get it checked out it doesn't sound like it's gonna get any better. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
mitchntx
08-26-2002, 10:32 AM
When you make that turn and you hear that noise, once you straighten out the wheel, is there a difference in the brake pedal?
I am the victim of a "long pedal" whereby the hubs have a small amount of play, causing the rotor to knock back a caliper piston. This results in a long stroke of the brake pedal so that it moves the caliper piston back against the rotor. It's another symptom of bad hubs/bearings.
Check for a tire rub on the inner fender liner. Mine rub the inner liner, when I turn hard.
Finally, slotted and drilled rotors will make a noise.
Send my $100 via Paypal to ...
mitchntx@charter.net
<img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<small>[ August 26, 2002, 10:33 AM: Message edited by: mitchntx ]</small>
Quickin
08-26-2002, 11:25 AM
[QUOTE]Originally posted by mitchntx:
[QB]When you make that turn and you hear that noise, once you straighten out the wheel, is there a difference in the brake pedal?
No difference.
No rubbing.
This has been happening for a long time with my stock factory rotors. The Erads are amazingly quiet.
Quickin
08-26-2002, 11:30 AM
[QUOTE]Originally posted by wrencher:
[QB]Have your front end checked out. Is it more of a rapid repeating noise?
Not really. It's silent when I'm straight, then a constant steady grinding sound when slightly turned to the left to change lanes. Also, when going straight, yet staying in my lane, I can take the wheel and do a bunch of quick, right center, right center, right center and for every quick right center movements, I would get the grind then quiet, grind then quiet, grind then quiet.
Quickin
08-26-2002, 07:00 PM
[QUOTE]Originally posted by Ben99Z28:
[QB]replace your right caliper, you can get one from autozone or pepboy for like $70(included $35 core charge), if that doesn't resolve the problem then it could be the wheel bearing. another thing to try is have the passenger stick their head out while you're turning right and make sure the noise is coming from the front instead of rear, I had similar problem happened to me like few months ago, it seems like the clunking and grinding noise was coming from front but found out it was my rear differential
Why change the right caliper?
The vibration is only felt on the drivers side floorboard, the passengers can't feel it but can hear it easily.
TUFFLS1
08-26-2002, 09:03 PM
when are we going to try the wheelbearing switch them from left to right its not hard and wont cost you anything and it is the same bearing from left to right
Quickin
08-26-2002, 09:18 PM
[QUOTE]Originally posted by TUFFLS1:
[QB]when are we going to try the wheelbearing switch them from left to right its not hard and wont cost you anything and it is the same bearing from left to right
I found out today from ARE that my motor will be on a truck this Wednesday. Which means next week Monday my car will be in the hands of the very capable Mike Norris at Norris Motosports (he's installing my motor,tranny,rear-end, suspension and exhaust) so I'll just let him figure it out.
I will let everyone know what it was.
wrencher
08-26-2002, 09:27 PM
If your noise changes intensity w/vehicle speed on right turning then it sounds like a left wheel bearing.
Quickin
08-26-2002, 09:51 PM
[QB]If your noise changes intensity w/vehicle speed on right turning then it sounds like a left wheel bearing.
That seems to be the most popular guess. How much do they cost for both front wheels and where is the best place to get them?
Also, will my tech be able to tell if there bad just by looking at them?
Ben99Z28
08-27-2002, 12:37 AM
replace your right caliper, you can get one from autozone or pepboy for like $70(included $35 core charge), if that doesn't resolve the problem then it could be the wheel bearing. another thing to try is have the passenger stick their head out while you're turning right and make sure the noise is coming from the front instead of rear, I had similar problem happened to me like few months ago, it seems like the clunking and grinding noise was coming from front but found out it was my rear differential <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
Ben99Z28
08-27-2002, 07:54 AM
if I were you I would replace both front calipers and wheel bearings.
Quickin
08-27-2002, 11:46 AM
[QB]if I were you I would replace both front calipers and wheel bearings.
Why the calipers if there not bent?
steve
08-27-2002, 01:40 PM
i say wheel bearing.
steve frank
wrencher
08-27-2002, 09:33 PM
You cant tell if bearing are bad by looking at them .They are a sealed hub race & bearing all in one unit + abs wheel speed sensor. But when they are off vehicle you can feel a bad one by holding mounting flange & spinning hub with other hand, you'll feel it's not smooth when turned , compair to a new one you'll feel it.
Quickin
08-27-2002, 09:48 PM
How much $$$ for two new ones?
wrencher
08-27-2002, 10:49 PM
I think there around $160 apiece not sure though.
GREEN GOBLIN
08-28-2002, 12:04 AM
We should have made it a poll, because wheel bearing is out front strong, by the way, that's my guess too! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
BYE RICE
08-29-2002, 01:32 AM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by EXTREME RACING T/A:
<strong>We should have made it a poll, because wheel bearing is out front strong, by the way, that's my guess too! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I said it first! <img border="0" alt="[judgement]" title="" src="graemlins/gr_judge.gif" />
CashDudeHomie
08-29-2002, 01:34 AM
I am going to guess bad left lower control arm balljoint. <img border="0" alt="[Fluffy]" title="" src="graemlins/fluffy.gif" /> Man I hope I win 100 bucks!!! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
StevieZ
09-03-2002, 04:19 PM
So was it a bearing or what?
Quickin
09-03-2002, 05:17 PM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by StevieZ:
<strong>So was it a bearing or what?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">My motor was delayed, it ships tomorrow from ARE. I should know what this problem is sometime next week.
M3EATER
09-03-2002, 05:37 PM
Another vote for ...
Wheel Bearing ......
M3EATER
Do all of the wheel bearing votes....split the $100 ?
Quickin
09-04-2002, 01:17 AM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by M3EATER:
<strong>Do all of the wheel bearing votes....split the $100 ?
<img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">That's allot of checks to write.
PewterZ
09-16-2002, 01:18 PM
This same thing happened to me and it turned out to be the calpier bracket had gotten loose somehow...the 2 bolts on the back of the bracket weren't torqued down good... ?????
Quickin
09-16-2002, 08:09 PM
HMMMMM, I can check that tomorrow. I think my bracket is bent to tell ya the truth.
WEASEL
09-17-2002, 02:28 AM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Quickin:
<strong>HMMMMM, I can check that tomorrow. I think my bracket is bent to tell ya the truth.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I have a similar problem as yours and it's driving me nuts and it comes and goes so it's hard to pinpoint.
Sometimes when I'm driving and steering towards the right, I can hear the left front rotor dragging and squealing. If I turn it ever so slightly to the left, it goes away. If I stop, put it in reverse, back up fast and do an "emergency" stop, it clears the problem up or greatly reduces it. <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> <img border="0" title="" alt="[Roll Eyes]" src="images/icons/rolleyes.gif" /> <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" />
The pads look to be wearing evenly particularly as long as this has been going on. The guide pins are greased. The caliper bolts and lug nuts are torqued to spec AND I can take my hands off the wheel and it will brake in a straight line.
One problem it has caused is more heat cracks in that KVR CD rotor.
I've got a junkyard caliper and bracket I need to rebuild and switch out to see if that fixes it but can't find the time.
My calipers are painted and I wonder if maybe brake dust or something on the paint is somehow causing the pads to stick. Maybe on the bottom edge and when I do a hard reverse brake, causes them to realign themselves.
PewterZ
09-17-2002, 09:10 PM
<strong>HMMMMM, I can check that tomorrow. I think my bracket is bent to tell ya the truth.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Well damm...that could be your problem....
