What size draglites up front?
I just bought some 15x10 draglites for the rear and am gonna order some fronts next week. what size is everyone runnin up front on the street? Some people told me that 15x3.5's would not be good on the street, is this true?
-Sean
-Sean
Originally Posted by dustin99a4
no, you will be fine running the 15x3.5 on the street. i have had them on my dd since october and have had no problems. just take it easy around corners
Cool, what size studs and spacers?
If is your daily drive, you will feel safe running wider than 3.5 in the front, I have 15x3.5 but doesnt feel very safe man to be honest, and to put something on your car that will be unsafe is not worth it , but is up to you is just an advice, so if you run 3.5 you will need 1.75" backspacing, shank style lug nut 12mm x 1.5 thread size, 1.300 - 1.380 in shank length, and a 0.679 - 0.687 in shank diameter, ARP wheel studs and 5/16" spacers.
You might need to grind a little still.
By the way I never had problems with 15x3.5 fronts but I just hate feeling unsafe everytime I turn or high speeds in the highway
good luck
good luck
I have used them on several cars, but they aren't DOT legal, just an FYI. As long as you remember you have a very small contact patch for braking and cornering, you'll be OK. I wouldn't daily drive on them personally, but my camaro runs on them 100% of the time, only rims I have right now. I just don't drive it alot though.
15x3.5 Draglites up front, stock studs, no spacers. I drive the car all the time on the street with absolutely 0 problems, ever. Don't be afraid to do a little grinding...
15X3.5 up front on mine as well. Take it easy around corners and it's fine. Sometimes a bump going around a corner or at higher speeds feels scary, especially with no front sway bar lol
