car is stuttering at WOT!! whats going on?
here is what is going on! my car has been sitting in the shop for a month waiting on all the new tranny ****. i went from t56 to th-400. i havent had it retuned for the th-400 because it is a manual shift just like the t56.
last night on the way home at 3:45 AM i was cruisin down the street and it was like a ghost town on this night. And what do you know a bright green bike pulls up. so i decide once we start going about 60 why not so then I shifted back to 2nd and mashed it. well for the first 3 seconds the car worked and then it started bogging when it tryed to hit full boost or makeing a werid turbo studder noise.
has anyone ever experienced this?? car was around 200 degrees
do i need to retune the car. maybe its a fuel problem!?!? i never had this problem with the t56
You weren't logging while driving home? Just tune it and forget it?
Did you check the impeller on the turbo? Does it spin freely? I'd check that, simple enough for you to do, especially if you heard a "weird turbo noise."
The info you gave is pretty vague, can't point you in a specific direction. Check all hoses and clamps, maybe you have a loose/torn hose and its causing some boost leak problems.
Maybe you hit the limiter in 2nd?
hmmmmm the limiter isnt till like 6900 and the shiflight is set at like 6300 and i never saw the shift light....
the car was tuned for the six speed like 5 months ago never had a problem and i barly put the 400 in it and this was the first time stepping on it.....and this happend i wanted to see if it would do it again so i half throttled it making 5 pounds gradualy but once it tryed to hit full boost the car shuts down well studderd! i hope i didnt hurt nothing!
waht noise does it make when it slips?? also what happens when you have detonation maybe its from the heat?? even though it was 3 in the morning still like 90 outside
You will hear detonation. It will sound like ping pong ***** are in your engine. Not a good sound to hear....ouch
well there are 2 kinds of detonation one you can hear and one you cant i didnt know that it can make you car studder that bad! took it out today and it didnt studder once what the hell is going on?
