how do your support the nose?
I'm not right now, I've heard eventually you will have problems if you don't. Less than 15 passes on my setup though, it doesn't see a lot of race time because I've had some bad luck breaking stuff
No support here, it still attaches at the middle & sides, I cut out the center for airflow. There's not much weight in what's left. Car has about 400 miles & 40 or so passes since I did it. You could probably tie it to the bottom of the IC.
1 Post
