BraemerZ28
07-16-2006, 07:12 PM
Hi all,
Just finished putting in a new set of Motive Performance 3.90's in place of my stock 3.42's. Test drive showed no noise on throttle, no noise on deceleration, but a noticeable whine at very slight throttle when engine speed is matching ground speed (if that makes any sense). :confused: It's not bad (almost none) in 1-4 gears around town, but you really notice it in 5 and 6 above 45 mph.
The install went nice with pinion depth being right on the mark and solid pinion spacer being shimmed properly for exactly 15 in-lb of pre-load. The contact pattern matched the install sheet picture very well. It was centered between the root and top of the tooth with our only concern that the slack side may have been a tiny bit too close to the inside of the ring gear. But, it still matched the picture so I think we're OK there.
The only spec that we "cheated" a bit was the backlash. We put the stock side to side shims back in and ended up with .006" while the Motive kit called for .008" to .012". We had another set of gear instructions from a different mfg for a friends' 3rd gen, and those instructions said that .004" to .008" was OK. So, we stayed with the .006" and put the deal together.
So, my questions are
1. Could our lack of backlash be causing the whine?
2. Can I expect the gear to break in a bit to the point where the whine may get better?
3. Or should I just pull it appart and shim the carrier to get my .010" backlash?
Thanks for any help,
Scott
Scott
