New motor.. oil pressure questions.
Old 07-16-2006, 08:52 PM
ineedashortblock's Avatar
Default New motor.. oil pressure questions.
Just got my car put back together with the new motor.
Forged 347,
Diamond forged pistons
lunati pro mod rods
stock crank
arp main studs, lunati rod bolts
clevite h series bearings throughout
and a ported ls6 oil pump
upon warm start up the car will make 55-60 lbs of oil psi at idle. today was the first day I really took it out, and I didn't romp it hard but it did see 4500 rpms a few times. Upon the car warming fully up, I noticed oil psi drop. It appeared to be 55-60 under full throttle and right at 30-33 lbs at idle. Bad thing to me was the fact that the car under 2k - 2500 rpms was only at 39-40 lbs of pressure. I noticed however that at 2500 rpms the oil psi would suddeny jump 5-10 lbs to around 48-55. It was an all of the sudden jump that was easily reproduced. however if I romped it, the oil psi would immediately jump up to 50-60.
My question is, anything I need to be worried about? or just run it? Before the car blew up before it wasm aking great pressure, 40 at warm idle and 55-60 at cruising.. so that is what I have come accustomed to.
Any input is appreciated.
Old 07-16-2006, 09:47 PM
slowpoke96z28's Avatar
get a mechanical oil pressure gauge on it and see what it says. i have heard of people getting screwy oil pressure reading by getting the o-ring on the pickup tube pinched and not sealing properly or a machine shop leaving out a galley plug. you'd think you'd have no pressure at all if either of these were the case, but theses new sbc's are a little different.
Old 07-16-2006, 09:49 PM
Boostaholic's Avatar
What plugs are there that can be left out on the LS1 and do that?
Old 07-16-2006, 10:07 PM
there is one on the back left side
Old 07-16-2006, 10:17 PM
one way to tell is by checking the dipstick level at idle. if you have oil pressure at idle, but the oil pan is still full, the oil pan will have to come off and see if the o-ring is pinched. if not, the rear cover has to come off to see if that rear oil plug is in place and not just letting oil run back into the pan.
Old 07-16-2006, 11:10 PM
John02SS's Avatar
That is normal pressure for a forged motor. The bearings tolerances could be a lil loose causing it. Mine is about the same as yours. They say as long as you have approx 7 psi for every 1K rpm your turning you are good.
Old 07-17-2006, 01:09 AM
thats about what my oil pressure is at, mechanical autometer gauge
Old 07-17-2006, 01:10 AM
Around what exactly does yours push out? PSI wise per rpm?
Old 07-17-2006, 01:19 AM
I get 35-42 at idle
Old 07-17-2006, 01:46 AM
Originally Posted by Boostaholic
I get 35-42 at idle
What about at cruising? does it stay around 40? Thats what i am worried about.
Old 07-17-2006, 01:47 AM
Yeah, I cruise at a lot higher rpm, TH400 and 3500 converter
Old 07-17-2006, 03:47 AM
JMBLOWNWS6's Avatar
Mine was doing this and I spun a rod bearing. Just a heads up. Forged 347 also. I took the motor back out with 500 miles on it and made my builder redo it. Because what you decribed is exactly the way mine was acting. And yes I put the mechanical gauge on it.
Old 07-17-2006, 08:30 AM
so yours was jumping up at idle? mine doesn't seem to jump, I think part of my lower oil pressure is some of the oil goes to feed the twins
Old 07-17-2006, 11:37 AM
Any more input is greatly appreciated.
Old 07-17-2006, 11:05 PM
JMBLOWNWS6's Avatar
True. But my blower takes off the same way as your turbos.
