Florida Members - 10 Bolt from 99 t/a
View Full Version : 10 Bolt from 99 t/a
ls1mongrel
07-17-2006, 09:50 AM
I just bought a 12 bolt, and wanna sell this , car has 40k on it and about 20 passes on motor, never sprayed with this rear, its works perfect, whines a little on decel, always has, had ratech deluxe install kit, with gear install, had everything check when gears were installed , has richmond 3.73 gears in it, t/a girdle, welded tubes, its 4 channel , its complete with backing plates but not any brakes or calipers. Asking $500 complete, $400 with no backing plates and $300 with no backing plates and no girdle ! Ready for pickup !
five0killr
07-20-2006, 06:30 PM
whats welded tubes, and im kind of oblivious to what a 4 channel is, so when you say minus the 4 channel, whats that mean?
ls1mongrel
07-20-2006, 06:50 PM
Welded tubes just helps strengthen the rear a bight, the axle tubes are press into tjhe center housing, I had them welded to help a bit, and 4 channel is for abs/tcs rearend
ls1mongrel
07-24-2006, 05:48 AM
Bump!
ls1mongrel
Bump !
ls1mongrel
07-25-2006, 02:29 PM
Bump !
Predator T/A
07-25-2006, 03:48 PM
you may want to consider dropping the price a little 500 is bit much for 10 bolt........and if it is whining on decel sounds like there may be a pinion bearing problem or the backlash wasnt set right
ls1mongrel
08-02-2006, 08:43 AM
Bump !
presto_z
08-02-2006, 03:55 PM
how loud is the whine.... is it cause of the gear swap??? richmonds are naturally louder then stock...... pm me with more info
ls1mongrel
08-18-2006, 11:37 AM
Bump !
396D1SS
08-18-2006, 09:19 PM
wanna sell just the cover?
ls1mongrel
08-22-2006, 09:51 AM
If i can find someone to buy the rest of it I will, ILl let ya know !
