Problem after turbo install
Got a issue with the turbo set up I just put on yesterday. To start it off the kit is an modified sts with a t70 and front mount running @ 7psi mount. Here is the problem, When I start the car up the exhuast pipe spits out oil for the first minute until the turbo is warmed up then it stops. It acts like when the car sits oil runs out into the turbine. This setup was used I am pretty sure I got the oil pump wired up right. Do you guys think it is a oil seal or should leave the ignition for a minute after I shut down the car to let the oil pump run. The car runs pretty good though its hasn't been tuned yet and goes like hell. Thanks for your inputs.
Thats a common problem on the STS cars. You need to leave the key on for a few seconds and let it pull it out. It normally happens after the turbos are used for awhile not when there new. I would say the seal does have some wear and you may need to look at getting a rebuild.
Your not alone in this fight. I posted a thread earlier about oil flying out of the pipe, but my problem is that it wont stop. Everyone is telling me that my pump is to blame. Im about ready to push it off a mountain.
Restricted User
Originally Posted by Boostaholic
Well if your turbo is low enough where you need a pump its common practice to cycle the key after turning the car off and sucking the oil out of the turbo.
