Heat from headers
Old 07-17-2006, 08:57 PM
slowscott's Avatar
Default Heat from headers
Saw a van burning to the ground on the side of the road today. Made me wonder how much more heat are my new headers (QTP) transferring to the surrounding engine bay than my old stock manifolds? Should I cover anything in heat wrap or am I being paranoid?
thanks
Old 07-17-2006, 09:08 PM
Order 66's Avatar
Your manifolds generated more heat then your new headers. Stainless hold in the heat better. Relax, your good!
Old 07-17-2006, 09:13 PM
slowscott's Avatar
I know stainless holds heat better but the old manifolds are about five times as thick and did not take up as much space.
Old 07-17-2006, 09:22 PM
tylerz28ss's Avatar
I can tell ya that I put the pacesetters on this weekend w/ the ceramic coating and I couldn't believe how much cooler the engine compartment was! Just keep anything that could burn away from the headers...
Old 07-17-2006, 09:30 PM
z28_n_tx's Avatar
im curious as well...my pacesetters (coated)get super hot within 2-3 minutes after i start the car. I've also noticed that my car gets to operating temp. in half the time it used to (It might be the texas heat ). I find my self checking the temp. gauge very often when i drive it
Old 07-17-2006, 09:37 PM
2 SSlow's Avatar
my temp gage is broke...i have mac mids NOT ceramic coated. They had the HTS (or whatever) coating that is flaking off. I have never had any problems with the heat from the headers. They have been on the car for over 20,000 miles in less than 1 year with no probs.
Old 07-17-2006, 09:59 PM
Luna's Avatar
Cars with LTs will always run cooler than those with stock manifolds, the increased surface area of the LTs combined with better exhaust scavenging, and a better heat conducting material PLUS a ceramic coating equals a much cooler engine bay then you've ever had with stock manifolds.
z28_n_tx's Avatar
im really starting to worry about this now...i went to the gym which is like 2 miles away, came home parked the car,1 hr later went backoutside to check on the car after reading the thread and the whole engine compartment is still hot including the slp lid.. it seems like every one else is running cooler.
any have any input???
Old 07-17-2006, 11:01 PM
That's what she said...
TheBlurLS1's Avatar
Mine is probably smoking hot right now, and I haven't driven the car since yesterday.
Texas heat FTL.
Old 07-17-2006, 11:07 PM
we_todd_did's Avatar
should be less.
Old 07-18-2006, 12:02 AM
Andros's Avatar
u should get header wrap if ur really worried about it. but it'll be tough to put it on now unless u wanna try to put it on anyways.
Old 07-18-2006, 08:05 AM
2 SSlow's Avatar
seriously you are okay. in this weather i only work on my car in the morning becuase it never cools down enough for me to start wrenching under the hood. lol
if you are having heat problems, check out the cooling system of the car...
Old 07-18-2006, 08:07 AM
Grimes's Avatar
you'll be fine. as long as there is a little air clearance between things and the header, don't worry.
Old 07-18-2006, 06:07 PM
Order 66's Avatar
Header wrap is the worst thing to do. It will retain moisture and can cause cracks. If you want the best under hood temps, stainless header with the Jet Hot 2000 coating. Its list tar and hold the heat in very well.
Old 07-18-2006, 06:18 PM
TransAmMan's Avatar
LOL before I put my pacesetters in I swear that my engine compartment when opened, in the winter... was blazing hot... i swear all the parts inside were glowing orange.
Old 07-18-2006, 07:08 PM
tylerz28ss's Avatar
I was driving around at the beach one night with my LT1 and parked it and opened the hood in the garage with the lights off, and the stock manifolds were glowing pretty good...first time I've ever seen manifolds glow! I wasn't driving hard or anything...
Old 07-18-2006, 10:27 PM
camaroextra's Avatar
Header wrap is dangerous, if you get a little oil on it you may as well light your car on fire. Have them ceramic coated! check the link in my sig for details
Old 07-19-2006, 01:40 PM
sdbrown84's Avatar
Stainless uncoated/unwrapped is just fine. They get hot (what won't with exhaust gasses) but don't cause anything to worry about. 110* weather here in PHX and I'm still good.
Old 07-19-2006, 01:57 PM
Beasst8's Avatar
Check out the engine dyno video on the lingenfelter site. The 427 TT on the egine dyno, the turbo manifolds glow bright red hot. Its kinda cool. I wouldnt worry but you engine being to hot. I mean you do live in Texas. I used to be the same way when I was in So Cal. It was all in my head. HEHE
Old 07-19-2006, 02:03 PM
2 SSlow's Avatar
half the problems/noises with our cars are in our heads
