can i run Patriot Dual valve springs on these heads..... need quick answer..
Old 07-18-2006, 02:41 PM
2002/Black/SS's Avatar
Default can i run Patriot Dual valve springs on these heads..... need quick answer..
i have a stock block, with lq9 6.0l heads about to go in, can i run the patriot dual springs on the stock 6.0l heads with stock cam,stock rockers and stock valves without puting to much pressure on them? do i only have to change to hardened pushrods?
(also im probaly going to put a z06 cam in durign the head install, if that matters)
Old 07-18-2006, 06:10 PM
Cheatin' Chad's Avatar
You'd be better off running Comp 918's with that cam in my opinion.
Old 07-18-2006, 07:50 PM
im doign a turbo build........ so i need the extra seat pressure, i juts need to know if the rockers etc can handle it
Old 07-18-2006, 09:14 PM
yeah they'll be fine.
What amount of boost are you planning to run?
Old 07-18-2006, 09:25 PM
8 pounds (maybe 7), shooting for 500RW with a t70 front mount, do u think ill need a timing chain? im also proably putting a z06 cam in when i take off the heads
Old 07-19-2006, 03:05 PM
7-8psi and 6500rpm should be fine with 918s when using a Z06 cam. Just something to consider.
Assuming you are running a 2.00 IV the 7-8psi you are planning on running will require and additional 21-24lbs of spring pressure over what you would need N/A to insure proper valvetrain operation.
A timing chain replacement is good insurance IMO. An LS2 chain should be more sufficient.
Definitely get some good pushrods.
good luck with your project!
