Oil Cap Stumble
Old 07-18-2006, 03:50 PM
WhiteMamba's Avatar
Default Oil Cap Stumble
Quick question.
After Driving my z around for a while I noticed this.. .
I pop opened my hoood, ( While the engine was idling), then
I removed the oil cap , the car seemed to stumble suddenly ... As soon as I put it back on its fine...
Is this normal.. ( I removed it a couple of times. just to check..) I did the same thing every time... It stumbles very slightly. ( It won't turn off or anything...
I even tried placing my hand over the filler cap, for a short while while the engine was idling .. then removing it.. after removing it ... It would stumble slighly also..
Is this normal
Thanks in advance.
Old 07-18-2006, 04:01 PM
2 SSlow's Avatar
if your PCV is still hooked up with will make a vacuum leak, explaining the stumble
Old 07-19-2006, 12:34 AM
WhiteMamba's Avatar
So I guess the stumble should be normal.. ( When I remove the oil cap while its running)
It stumbles... Like changes in Idle speed..
Old 07-19-2006, 11:13 AM
2 SSlow's Avatar
yessir...no biggie
Old 07-24-2006, 02:15 AM
WhiteMamba's Avatar
Noticed this when the car is idling.... at normal operating temperatures... and I open the oil cap .. The Car stumbles slightly ... You can hear a change in idle speed.
Then If I put my hand on the oil cap hole,
it creates a suction.. If I remove it it stops.... ( Changes in Idle Speed again)
Is this normal.. . Or Does this means BAD RINGS..??
My Brothers 99 Vette Does not do that.. I tried it on his..
( Had his car Idling ,then I proceeeded to take the oil cap off.
and his car did not stumble.)
Thanks
Old 07-24-2006, 02:19 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Is there a different PCV setup on his car?
Old 07-24-2006, 02:27 AM
WhiteMamba's Avatar
Who's .. The Vette... No. Stock.
Mine (THE Z) .. . I am more worried about the Vaccum It creates
when I put my hand in the oil cap.. and why it stumbles too..
It tends to ilde at at about 1000-1100. ( Manual)
BTW... My PCV is stock...
Someone...
Can you all check to see if you all's car does this while idling
at normal operating temps
Check to see if stumbles or creates a vaccum with the oil cap off.
Old 07-24-2006, 08:10 AM
oange ss's Avatar
it's suppose to work like that
Old 07-24-2006, 11:54 AM
WhiteMamba's Avatar
???? My 05 Silverado and brother's 99 vette doesn't do it..
Old 07-24-2006, 05:40 PM
oange ss's Avatar
they most likely have the fixed orifice valve
Old 07-26-2006, 08:34 PM
WhiteMamba's Avatar
Need to check my PCV Valve to see if its clogged!
