Magic Stick 3 owners -- how drivable in 6th?
Old 07-18-2006, 05:17 PM
Arizona Mike's Avatar
Default Magic Stick 3 owners -- how drivable in 6th?
I'm interested in manual transmission stock or 3.73:1 rear. Can your cruise at 65-80 in 6th without bucking? Do you get any pickup when you step on it or do you have to downshift?
Thanks, Mike
Old 07-18-2006, 05:52 PM
mmorrison09's Avatar
I have the stock 3.42's and i can cruise in 6th at 60ish without bucking, but i have to downshift if i want to pick up speed quickly if this helps.
Old 07-18-2006, 06:40 PM
obrien24's Avatar
I have 4.10 gears in my car and I can cruise around town @40 mph in 6th with out any bucking. I only get bucking in the lower gears when I drive in and out of my neighborhood.
Old 07-18-2006, 09:27 PM
RoastEmSS's Avatar
same with my torquer
Old 07-19-2006, 12:29 AM
import slayer's Avatar
what is bucking?
Old 07-19-2006, 06:29 AM
Specialized's Avatar
When the car's idle is lopey and powerful enough to force the car to move non linearly (if that makes sense). The car moves to the idle / piston / crank movement of the car.
Old 07-19-2006, 07:46 AM
alans02z's Avatar
Nope. Its when the car is in gear and it surges, jumps, bucks, jerks, or whatever you want to call it. Has nothing to do with idle out of gear.
Old 07-21-2006, 01:20 AM
Thanks for the replies. It sounds like the first two replies correspond to 1400 RPM and 1100 RPM respectively. I'm plesantly suprised. I just want to make sure I don't loose 6th as a fuel-efficient gear for long highway trips. It sounds like I won't have that issue.
Mike
Old 07-21-2006, 07:33 AM
1936FordPU's Avatar
Get your tune fixed.
Old 07-21-2006, 07:34 AM
1936FordPU's Avatar
Mike
You wont have that issue if you have a competent tuner that can make legit changes in your VE table.
Old 07-21-2006, 05:23 PM
obrien24's Avatar
It only bucks if I let it idle in gear. mainly in 1st or 2nd, which allows me to move through my complex nice and slow.
