Corvette Performance - Anyone with pics of underneath car
GTFORMULA
07-18-2006, 06:49 PM
I need some pics of underneath on a C-5 without trans or frame in if you have them . Im trying to get an idea for my solid axle conversion. Thanks again for any help. If anyone knows the distance from wheel mount to wheel mount with the suspension loaded Id appreciate that also.
GTFORMULA
07-23-2006, 08:21 PM
to the top
GTFORMULA
07-24-2006, 04:59 PM
WOW so many to chose from!!! I know somebodys got to have some.
Hi GT -
best I can do for you -
http://www.iammoon.com/images/vette/johns/underside1.jpg
best regards -
mqqn
GTFORMULA
07-25-2006, 08:33 PM
Thanks qwerty.
I really need some with no drive train and no fuel tanks.
I know someones got to have some with everything out.
chimazo
07-31-2006, 04:02 PM
http://redshift.homestead.com/Drivetrain/DT37.jpg
If you went with a solid rear, where would you put the tranny? Whatever you are thinking, it wouldn't be cost-effective. You might as well go with your own tube-frame chassis and mount everything conventionally and then figure out a way to attach the body. Or maybe take your drivetrain and stuff it in an F-body.
This link should have all the pics you need to see the difficulty in what you suggest .
http://redshift.homestead.com/Drivetrain1.html (http://)
GTFORMULA
08-01-2006, 07:27 AM
Those are good pics of pretty much what I needed.
I have done my research and to get a bulletproof powerglige, 9inch,and suspension in the car it will end up costing about 7500-8000 dollars. There are many people that would say this is alittle crazy but I plan on going high to mid 8's and dont want to worry about the stock rear constantly blowing out.
Everyone trys to put th400's in ,or 4l80e's but it still wont fix the rearend problem. Plus there is no real way to dial the suspension in on a C-5 to different track conditions.
allthrottle&nobottle
08-01-2006, 10:02 AM
I am sure you have seen these right.......
http://www.learntodragrace.com/images/12bolt.jpg
http://www.learntodragrace.com/newturbogallery.htm
GTFORMULA
08-01-2006, 02:11 PM
Yes Ive seen those. That is similar to what Im going to do. None of those pics really show the body attaching points . I also think I can use more F-body off the shelf parts for mine. We'll just have to see.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
