Big Stuff 3 - Turbo guys, need help
I just order my BigStuff 3 and I would like to look at some turbo tunes before I start playing around on my car. Here is a rough basis of my setup.
Forged 370 ci with ported LQ9 heads
PT-88
Water to Air intercooler
Powerglide
in a 2500 lbs car
Please e-mail them to
FD3SLS1@sc.rr.com
Thanks
Josh
PT-88
Powerglide
in a 2500 lbs car
FD3SLS1@sc.rr.com
Thanks
Josh
Well unless you have the same injector size and rail pressure you won't have a lot of luck using someone elses fuel tables, the timing and AFR tables will be fine though
are you using a 3 bar map sensor?
PT-88
Powerglide
in a 2500 lbs car
FD3SLS1@sc.rr.com
Thanks
Josh
PT-88
Powerglide
in a 2500 lbs car
FD3SLS1@sc.rr.com
Thanks
Josh
Hey with that tune what size injectors were you running and how much fuel pressure.
If anyone else has a tune they would like to share please do.
Originally Posted by MIGHTYMOUSE
email me and ill send my current cal MIGHTYM0USE@comcast.net
