Should I go 17" or 18"? I'm on the fence...
I will be going with the Z06 motorsports so at least that's been decided, but would like your all's opinions about what size to go with. I like the look of 18's but don't like the fact that the GS-D3's only come in 295's for the rear I would consider going with 17's to get a 315 on the rear but I am just confused as to which I want more, the larger wheel or the fatter tire. I will be 500+ rwhp so I'll need as much tire as possible but I don't go to the track much, if at all, so it would be mainly for street handling and hooking if i wanna row through some gears. Yo soy Help me out guys.
first of all, a 315 (nitto 555r exempt) will look rediculous and will be dangerous on a 17x9.5 wheel. so you'll be using a 275/40/17 tire, if thats too small... theres your deciding factor.
and a 295 is perfect for a 18x10.5, so i dont see why that bothers you
also, because of the rivets on the motorsport wheels, the wheels themselves appear smaller than they really are, therefore a 17 might seem like a 16, because of the rivets and multiple spokes.
there is no such thing as a 17x10.5 z06 wheel, the widest anybody makes is a 17x9.5, if they DID make anything wider than 9.5 i would be all over them lol
usually the only wheels that come in 17x11 are zr1's, and custom wheels like AR/boyd/fikse/etc.
295's will be just fine... and if you go with GS-D3's they run ALOT wider than most other brands in the same size... ive even heard that a 295 GS-D3 is as wide, if not wider than a nitto 315/35/17... so that gives you an idea.
also, traction isnt about the widest tire, its about the compound the tire is made of, for instance, you can get better traction from a 275/40/17 BFG drag radial than a 315/35/17 sumitomo tire, even though the DR is smaller in size, its made from a softer compound.
as for which 18" tire hooks the best, im not sure, im staying away from 18's due to the price of tires, but i hear nothing but good things about the GS tires in 17's, some even say they hook just as good if not better than a nitto DR, and im sure the same goes for the 18" GS-D3
Originally Posted by ArcticZ28
Yea, not sure what I was thinking on that one. Looks like I will be going with 18's since they come in 10.5, still wonder about what tires I should go with. I just don't think 295's are gonna be meaty enough.
as for width: on the street, width is for look and handling. straight line traction is almost completely unaffected. feel free to PM me if you have anymore questions but this is a subject i feel very strongly on.
i dont see anything wrong with a 9.5 wheel, and you'll probly get better traction with that 17x9.5 with a good DR versus a 18x10.5 wheel. and if you think about it, its only an INCH of difference, not much when you put it on your car
ok then that could be a problem...
so your running a street tire for sure... now you run into the sidewall issue like qwik mentioned, you'll have a smaller sidewall with 18's, reducing sidewall flex which is important for good traction.
18's are usually used for autox because they dont have alot of tire roll when turning hard.
Well, traction isn't absolutely crucial because, like I said, it's just a street that I drive around a couple days a week. I'm not looking to cut 1.4 60's on these, just want as wide of a tire as possible for best possible traction on the street in dry and wet conditions, and also looks. Bottom line is nothing beats the look of a 315 out back.
i understand that your not gonna be racing with these tires but at the same time do you wanna be spinning accidently from each and every traffic light? its up to you which is more important (form vs function). but i think the 17x9.5 will grip better out of the whole then the 18x10.5s. wider isnt always better
I got 17x9.5'' z06s all around because tires are much much cheaper. I still want to run a 315 so when I burn up my exisiting 275s I'm going to send 2 wheels to weldcraft and have them widened to 10.5''. Not sure if funds will allow you to do that, but its always an option.
