28" M/T Radials on WS6
Old 07-18-2006, 10:34 PM
Johnny5's Avatar
Default 28" M/T Radials on WS6
Can you fit the Mickey Thompson ET Street Radial Tire 275/60R15 which is 28" tall onto a stock ride height WS6 without modding the wheel wells?
Does having a 28" out back and 26 cause your ABS to fail? Does it matter if it does?
Old 07-19-2006, 10:36 PM
Johnny5's Avatar
damn.. does everyone just go to wider and more hammering then...
I may need 28"s to get me across the finish line but I don't want to bang the hell out of it just yet... anyone know if 275/60R15 will fit with NO BANGING?
Old 07-20-2006, 04:29 PM
Johnny5's Avatar
so no one has mounted up 28" M/T radials on a 15x10 rim?
Old 07-21-2006, 09:00 AM
tektrans's Avatar
I have run the 325 50 15's on a 6.5 bs rim with now wheel well mods at all.
Old 07-21-2006, 09:40 AM
1BDHWK's Avatar
Ran 325/50/15's on Bogart wheels. Had to slightly message on the inside. Not much at all. Adjustable LCA's helped.
Old 07-21-2006, 10:29 AM
Johnny5's Avatar
Thanks to both of you. I've got Bogart Welded Rts for rims. So you didn't have to cut anything or roll the fender then? I guess I'm ok with some banging but not cutting.
Old 07-21-2006, 10:58 AM
1BDHWK's Avatar
No cutting at all. I rolled my fenders for my slicks, but it was not necessary. For such a big tire, they fit well.
Question: Do you already have a set of MT radial tires? If not, I'm looking to move my 325/50/15's to get a set of QTP's for the street. Mine have 4 1/8th mile passes and maybe 20 miles on them. I can cut you a good deal, if you need some. Let me know. I have not put these up for sale yet, but will, here soon.
Old 07-21-2006, 12:42 PM
Johnny5's Avatar
Not yet. I have a set but they are the 26" tires. Put the N20 on and I need a bigger gear now to get through the traps in 4th. I have to kill these tires off first. Thanks though.
Sounds like you rolled them for slicks but you wouldn't have needed to do that for the radials?
Old 07-21-2006, 01:16 PM
1BDHWK's Avatar
Same problem here, going to a bigger tire.
No you do not. It will be fine for the radials.
Old 07-21-2006, 01:52 PM
ls1_doc's Avatar
i had 28x11.50 on mine and i had to trim the very bottom of the backside of the fender cause it was rubbing on launch. Also it does mess with your abs.
Old 07-21-2006, 02:39 PM
1BDHWK's Avatar
Oh yeah...I second that. I have no ABS, so I forgot to add that.
