pacesetter header install help!!
ok so i got the passenger side header on and i look at the top...there are 2 effing EGR plugs on it....that isnt normal is it? i have to block one off dont i??? and also..under neath the car there are 2 02 plugs on each side, but only one hole on each header... what do i do with the one extra plug that i cant plug into the header and which of the 2 do i plug into the header...the one that was up by my cats or the one that was at the bottome of the manifold?
ok but what do i do with the hanging sensor? just unplug it from the extension?? and which one should i plug into the header..the one that was by the cats or the one at was at the end of the manifold......what do u mean one plug is for AIG and one for EGR only the passenger side has to tubes...the drive side has one tube...what do i do with the extra tub that doesnt have the EGR pplug ontop of it?
OK the AIR system has one tube on each side and the EGR is the other tube thats on the pass. side, are u using blockoff plates for the EGR and leaving the AIR sytem or what? and use the 02s that were at the top of the cats to plug into the headers. then ull have to unplug the other ones from the sensors and use a ziptie so they dont hang down. this will set off the SES light,but if that bugs u buy 2 02 simulators or get it tuned out. o i almost forgot, ur gonna need 02 extensions for the ones plugging into the headers, cause if u havent found out yet, they dont reach
yea i have the o2 extensions....so if i wanted to keep the EGR what would i plug in there? or should i just put block off plates??? does it matter which tube i plug the A.I.R hose onto?
ull know what tube the AIR goes to cause it will only reach one of them, im not sure what u r asking about the EGR. u can just block it off but SES light will go off, other than that it has no negative effects
