Post pics of where your FI Guages are located
Just like the title says... where do you have guages mounted. I cant decide to go pillar or AC vents. Both have their ups and downs...
pillar, easy to see, just look a little left, but everyone can see it, at night they light up and people see it and it just screams I have a power adder!
vents- cant be seen by anyone, fit like their molded, but they are a little harder to keep track of.
Post pics of where yours are and why you like them there and your opinion on what you think.
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Any mod, could you make this a simple poll, 2 choices for TA, pillar or ac vents. Thanks!
__________________
I'f your your over 6' the piller pod only works with two guages. I'm 6'3" and have a triple pillar pod and can't se my wideband o2 sensor, its the middle gauge, it does have data loggin' thou. Gotta ride with a friend to see if i'm still 10.5:1 at 8psi
I'm about 5'11" and tend to sit more upright when I'm driving my car (ie....i don't lean way back gangsta style......). I like to have my arms bent at the elbows and up towards the wheel in a much more attentive manner.....this position seems to block the middle guage a little bit. I always keep the A/F at the top pod (so it is always in view)...fuel in the middle (sometimes can't see the very top of the guage where the needle lies....but I don't look at it much anyways), and boost at the bottom pod.
Ok, so i've searched some as well and found that in triple pods, some of the guages are blocked, so really they arent that easily seen. I'm leaning towards the vents, anyone have any good pics of TAs with guages in the vents? Thanks!
__________________
Didn't you just make this thread (or one just like it?) a week or so ago? https://ls1tech.com/forums/appearance-detailing/535452-guage-mounting.html
This one i would like to see some pics, other one was to see what most people used, got a few pictures but would like to see some more options. Yea its kind of close but the topic is still on my mind and that thread died so i figured i'd make one more dominated to pictures
__________________
BTW, i like your set up frost... a combo, can see the 2 in the pod well and the other in the vent, good thinking!
__________________
People with guages in vents... do you block off the vent at all? also where do you run the lines? Thanks
__________________
ok thanks, what do you use to block it off?
__________________
