ported tb
Old 07-20-2006, 06:45 PM
DSRCAM's Avatar
Default ported tb
can anyone show me how to port out my tb and how much hp increase will i gain?
Old 07-20-2006, 06:56 PM
02TaOwner's Avatar
http://www.geocities.com/wilwaxu/throttlebody.html
Old 07-20-2006, 06:57 PM
98hardtopZ's Avatar
www.installuniversity.com
Old 07-20-2006, 07:06 PM
radz282003's Avatar
Take your time and be careful not to burn through the thinner areas. Make sure you clean it out really good before putting it back on the carm too.
Old 07-20-2006, 07:22 PM
DSRCAM's Avatar
i didnt find it on installuniversity.com does anyone know where i can find the rub cap for the throttle body bypass mod?
Old 07-20-2006, 08:11 PM
Trunion King
bene's Avatar
Don't really need it but if you insist, you can go get them as a set in NAPA, Autozone.
Old 07-20-2006, 09:05 PM
98hardtopZ's Avatar
yea sorry, i forgot thats the one thing installuniversity doesnt have, it has all of the other free mods tho...
Old 07-20-2006, 11:25 PM
SIC LSX's Avatar
ive seen 10whp with T.B
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Check stickies.
and....
Old 07-20-2006, 11:26 PM
DSRCAM's Avatar
thats kool man thanks for the help!
Old 07-20-2006, 11:27 PM
DSRCAM's Avatar
is it cheaper to buy to the tb bypass kit as a kit or seperate?
Old 07-20-2006, 11:30 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
either way it is 10$ or 5$.
Old 07-20-2006, 11:34 PM
DSRCAM's Avatar
did u do the mod?
Old 07-21-2006, 12:48 AM
RrCoX22's Avatar
did u do the mod?
who gives a ****... it's something you can do with a blindfold on
Old 07-21-2006, 02:20 AM
Ubergeist's Avatar
Originally Posted by orangeapeel
Check stickies.
and....
I did see someone put a dyno of a before and after for a pnp stock TB. He gain 10whp.
Old 07-21-2006, 05:38 AM
Bo White's Avatar
Check stickies.
and....
www.ls1tech.com/forums/showthread.php?t=263689
I met him at the dyno to deliver it and seen the pulls. It was an A4 car too (head/cam/stall).
Old 07-21-2006, 07:10 AM
Trunion King
bene's Avatar
Dude all you need is barb fitting=+/-$1 from LOWES/Home Depot.
Old 07-21-2006, 07:16 AM
01SSRMS's Avatar
Either that or do like I did. Just get a 2 foot section of heater hose and run a complete new line from the top of the radiator over to the nipple on the driver's side head. That way no fittings or restrictions. I got the heater hose for $2.00 and then two screw clamps. So +/- $3.
Old 07-21-2006, 12:24 PM
98hardtopZ's Avatar
cheapest way to do tb bypass is go to autozone and spend 2.50 on 3 feet of 5/16's fuel line.....done..
Old 07-21-2006, 09:59 PM
BigE's Avatar
Yup, my car went from 293.5hp 100% BONE STOCK to 301hp with the addition of the P&P TB. I swapped it out on the dyno. Dyno runs were 20 minutes apart.
