those with dumped duals in here
Will aiming the dumps outwards help with the resonation at ~1500? Mine make it sound like a honda is chasing me for about 200-300 rpm on slow take offs.
thanks
thanks
Originally Posted by orangeapeel
Dumps = rattle
That is just a fact.
Originally Posted by ClemsonT/A
My duals dont make any sound that sounds even remotely close to a honda. I do have some rattles but I need to go under there and tighten things up a bit.
100% agreed. Of course I have Flowmaster Delta Flow 1 Chamber mufflers... so... yeah
I do get some resonance in the car about 1900 rpm for a split second if I am slowly accellerating in 6th gear, but thats it...
I'm guessing the effects will be minimal, but ive always had mine turned out.
And yeah, i get that too, maybe not at that exact RPM range, but close.
I think its a frequency thing of the pulses, and unless you get the resonation out from under the car completely, its just gonna happen.
For the record, my setup has no rasp and has magnaflows with turn-ins. But if I leave that flap that covers the trunk down, it rattles with a very raspy sound. I leave it up for now, but I'm going to get some foam or something to shut it up. If I were you, I'd seriously look at something loose causing your noise. If not something in the car, then a loose heat shield or bad hanger. Duals should sound smoooooooth.
