Tools & Fabrication - nasty paint question
View Full Version : nasty paint question
leonpiper69
07-20-2006, 09:33 PM
i put this in the paint section but i guess thats just a bunch of guys who like to talk about there wax jobs soooo............ can anyone here help?
http://www.ls1tech.com/forums/showthread.php?t=545180
fast377
07-23-2006, 12:24 AM
Looks like there is some sort of slovent trying to evaporate out from under the base...or moisture is getting built up in your lines and you are spraying water/paint out of your gun, or something contaminated your primer coat. Don't know really, I've never had that happen.
leonpiper69
07-23-2006, 08:46 PM
problem solved. the power went out cuz of storm so i let it sit for 2 days in between coats of base. and it was real hot and humid so i switched to a real slow reducer and it turned out that was soaking into the layer of base under it so it was reacting with itself. i waited another day, sanded smooth with 400 and went back to medium reducer layed it on in light coats. worked fine then cleared it a couple hours later. heres a pic.
http://www.ls1tech.com/forums/attachment.php?attachmentid=71101
http://www.ls1tech.com/forums/attachment.php?attachmentid=71102
67RSCamaroVette
07-24-2006, 12:10 AM
Awesome! Glad you got the problem fixed. Gorgeous color! Nice summit hat btw :judge:
