help no oil pressure...could this be why?
Old 07-21-2006, 01:44 AM
markp03's Avatar
Default help no oil pressure...could this be why?
ok guys i am doing a turbo setup on my 2000 camaro and I put in a double roller timing chain, well the timing chain came with these two shims to space the oil pump out. I fogot about them and i used a few washers to do it. so i go to start it up and i get no oil pressure. My buddy thought that because we did not use the shims, there is a huge gap on the sides of the oil pump which is now causing it to not work correctly... is this plausable?
Old 07-21-2006, 06:20 AM
See5's Avatar
Don't mess around get a new pump.
17801830 Oil Pump, High Volume, GM LS Series
Old 07-21-2006, 06:27 AM
PREDATOR-Z's Avatar
Yes, need to use those shims.
Old 07-21-2006, 10:57 AM
markp03's Avatar
think anyone local would have that oil pump? my car needs to make it to carcraft tommorow.
Old 07-21-2006, 11:01 AM
See5's Avatar
It is a GM part so--
