ARRRGGGG Blue Smoke!
1 Post
To start the story off my car has been running fine with no smoke. However on monday I noticed that it was blue smokeing. So I checked the catch can and it was fine. So after getting rid of the smoke it has magicly come back a month later. I got rid of the smoke origonally by blocking off the tube that goes from the top of my fast TB to the top of the valve covers. That worked great stoped the smoke instantly, but now about a month later it is back. I just have no idea what could cause it to go away then come back like it does. The last thing I want to do is pull the heads, but my only guess now is that it is either the rings or the heads either way it is not good. Any ideas just speak up.
Thomas
Thomas
1 Post
Originally Posted by kickassT/A
i thought you wanted valve seals put in those heads like a year ago.... if it passes a compresion check, then try valve seals
Thomas
Originally Posted by | Powered by Satan |
Patriot Heads FTL
time for the 408 Thomas
Originally Posted by Mike TexaSS
Spray the big shot.
