Dynamometer Results & Comparisons - a4 numbers
View Full Version : a4 numbers
BAM-BAM
07-21-2006, 11:39 AM
here are the results...i'm not much into dyno queens or dyno racing but here are the numbers..i'll try and scan the sheet later as right now my scanner is a hunk of S)*)&t.
best pull was 480rwhp and 433 rwt... track times best so far
11.10 @ 122 with a 1.55 60 foot this was in 85 plus heat and humidy rAce weight of 3850 with my big ass driving it.. this was on 17 inch zr1 all around and the hoosier drag radials
only susp mods are subframes, lca, and relocation brackets ...
this was on a dyno jet
here is the setup...
383
et 215 heads 58cc upgraded springs good for .650
comp..242/248 611/619
kooks 1.78 lt
2.5 true duals
10 bolt 373 with a girdle
fast 90 nw 90mm
4000 tci converter
42# injectors
just some info.....for what its wortrh
offaxis
07-21-2006, 05:00 PM
Great numbers man
