open exhaust on an LS1
0n an 01' C5, with full bolt-ons heads and a 236/242 cam and a lot of nitrous we want to run full length headers no cats, with an X pipe and no mufflers with resinated tips. This will cut the back pressure down to nothing, will we be fine, or will I end up bending valves in these $3000.00 heads? Any advice will be greatly appreciated.
I have been running open headers for a while. You should have no problem with running that set-up. The first time i ran it open headers it was fine for about a couple hours but then the O2 sensors started to act up and it ran like ****. So i made some 12" extensions out of piping at work and now it runs fine. Just extremely loud, and since your car will be cammed it will loud and sound like a beast at idle.
-Joel
-Joel
Originally Posted by charlie c5
You guys rock. Thanks for the feedback. I have turned the rear O2's off so they should be fine.
Guys, he won't be running open headers, he is saying no muffs. Headers> X pipe> exit at back.
Yes you can run that system if you can stand it.
You could put two magnaflow round tubes after the X to quiet it down a little with little or no effect on the flow.
