sleeperstyle
07-22-2006, 12:12 PM
ok- i just got done installing a new valve body with new shift solenoids since the one i had in the car before wouldn't electronically put the car in first gear (i had to manually shift the car into first) and i had no od. also. i suspected the 1st gear and the od were somehow linked so i guessed that once i got a new solenoid that 1 and od would work. WRONG!
now i have first gear, but i just cannot get the car to shift to od. i took it out with the scanner (hptuners) hooked up and selected 4th gear and nothing. didn't try to shift or anything. it is fine in every other gear but just seems that it won't command it to shift into od.
now- when i first took the car out i could've sworn it shifted to od one time and locked up like normal, but i couldnt' get it to do it again.
i also doubt that the 4th gear clutches are burnt out, since the trans was perfectly fine when i ran it a while back.
thanks in advance.
thanks in advance.
