Pulling the motor
Pulling the motor
My friend and I have the motor almost out of the car. I'm going to pull the motor from the top. I have a couple questions. 1)How hard is getting the motor from the tranny and the process to get it unbolted? 2)Does the pulley have to come out to get the motor out? 3)What should I do to protect the A/C system while the motor is out and how much A/C refrig will i need to get the system back up?
Thanks for link. I'm just trying to get some ideas before I climb under the car to see how to get the motor apart from the 4L60e, if anyone had a few things to look for or some time saving tricks to getting it apart.
Pull the starter and headers and unbolt the torque converter from the flexplate.. Dont try to pull the tranny out of the converter- I learn this the hard way the first time I pulled my motor, ended up damaging the converter.. Also, pull the heads off, it will make it easier to reach the top 3 bolts on the bellhousing..
I would also pull everything off the front of the engine (water pump, pullies, balancer)..
if you are going to take the heads off anyway then take them off now before the pull. the pulley doesnt need to come off. be sure to look for all ground wires still connected especially the lines and sensors behind the motor. be careful with the oil pressure sensor behind the manifold, do not break it. remove the ac and radiator along with the starter and you are pretty much done. if you havent double checked and tripple checked please do it. good luck man
Thanks guys... I have removed the radiator, a/c system, the alt., the a/c water pump, the coil packs, and the headers. I didn't really want to remove the heads so that the guy that will be working on building my motor can get an idea of what happen to the motor and what caused the coolant loss that I couldn't visually find.
If pulling the heads will make the job pulling the motor from the tranny easier then I'll make it happen. I didn't know how many bolts are holding the torque converter (four) and how many are on the bell housing (8?). Everything else is off labeled/bagged/numbered/cleaned. I've only got about 6 hours on the project.
The bolt at the top center of the bell housing is the worst, but if you buy or borrow a 3 foot extension and a swivel, you can easily see and pull the bolt by laying at the end of the tail shaft. There is no need to pull the heads.
Mike2000Z28,
I just removed my truck's 5.3L, and have to say the biggest challenge was getting separation from the tranny. I think most Gen IIIs have steel dowels at 3:00 and 9:00 o'clock on the bellhousing. Mine appeared to be rusted. I also broke my Oil pressure sending unit that SilverThriller mentioned so watch out for that.
Good luck,
Stroker2112
Good luck,
Stroker2112
Just got the motor back in my T/A. I pulled it from the bottom. I left all of the a/c intact, rad.,fans, and catback still in the car. Took 2 hours to pull it and 2 1/2 to put it back in.
I yanked the ac and radiator, shortblocked the engine, removed the starter, etc and it actually physically took like 20 minutes to pull it including removing the transmission bolts and motor mounts. BTW I love these style motor mounts, I'm used to the ones on my 67 which I hate. What I want to know is it feasible to install a longblock through the top on the F-body? I haven't found any write-ups about it, I would REALLY like to install a longblock with intake. Not to hijack, just kind of relates to this.
