pushrod question
Old 07-23-2006, 11:21 AM
Restricted User
WS6nJAX's Avatar
Default pushrod question
if i go with adjustable rockers, does it really matter if i use 7.40 or 7.35 pr's?
Old 07-23-2006, 12:41 PM
PREDATOR-Z's Avatar
Yes it matters, since on non pedestal rockers they perform a dual function:
1- They affect geometry on valve
2- They also affect lifter preload
On our stock system they have more of a preload effect than geometry effect since the rocker system is non adjustable.
Old 07-23-2006, 01:28 PM
Restricted User
WS6nJAX's Avatar
so what would i be looking at to make them work? just a normal pr length check? is it just a better idea not to use them for a mostly street driven car?
Old 07-23-2006, 07:05 PM
vettenuts's Avatar
There are a lot of advantages to using them, but some (like Crane for example) use a different arc arrangement and sit lower at the pushrod end therefore you need different pushrods. Best to measure, but once you do you have the advantage of being able to set your lifter preload.
Old 07-23-2006, 07:25 PM
Restricted User
WS6nJAX's Avatar
i ended up getting the comp type r lifters and the adjustables are what they say to use. looking to get a set of hs adj. rockers.
