diesel mechanic
Old 07-24-2006, 10:16 AM
X-running's Avatar
Default diesel mechanic
I have a 01 dodge cummins that I need help with. My dad was going down the street and the truck just turned off on him and now it wont start. it will turn over but just don't start and when it comes to diesel im clueless. So If anybody know a mechanic here in houston lmk
Old 07-24-2006, 11:24 AM
SLPformula's Avatar
did he put GAS in it. Every time gas is put into a deisel someone let someone borrow it.
Old 07-24-2006, 11:30 AM
TchargedLS1TA's Avatar
Bet ya the injection pump went out.. Its gonna be a costly repair.. Take it to HotRod Diesels in Hitchcock. 832-932-1432, ask for Mike. He know's cummins like no one's business...
Old 07-24-2006, 01:53 PM
X-running's Avatar
yeah only he fills it up, so no gas
Old 07-24-2006, 03:14 PM
treysoucie's Avatar
prolly a sensor or somthing. get it towed to diesel innovations. theyre probly the best diesel shop in houston.
theyre on fm1960 from jones rd. going towards 249 theyre on the right hand side.
Old 07-24-2006, 03:15 PM
treysoucie's Avatar
usually they have their race truck out there, its a plain white f250 powerstroke, dropped w/ some monsterous slick on the back.
heres their website:
http://www.dieselinnovations.com/di.php
trey
Old 07-24-2006, 04:38 PM
That's what she said...
TheBlurLS1's Avatar
The only thing that can go wrong with gasoliners is fuel or spark, diesels are only half as complicated.
Old 07-24-2006, 06:06 PM
kickassT/A's Avatar
i'd say either injection or lift pump. lift pump you could do your self. just go to oreilly's and get a holly blue pump to replace the stock dodge one. injection pump, i'd probably take to hotrod diesel if you're not confident you could do it. michael is a good guy, as someone else said before. the pump itself is expensive, so be prepaired for a little sticker shock.
Old 07-24-2006, 09:30 PM
X-running's Avatar
i think the truck might end up at diesel innovations who knows maybe something else will get done at the same time
Old 07-25-2006, 08:35 AM
treysoucie's Avatar
big oil? lol, w/ some monster injectors
Old 07-25-2006, 09:05 AM
redaddiction's Avatar
When's the last time he changed his fuel filter ?
Old 07-25-2006, 02:47 PM
estegeme's Avatar
lift pump went out, than the injecton pump went out, be ready to drop 2000 dollars, might as well get the FASS fuel system while its there, and hell with that on there. might as well throw some injectors in there. than hell just order the upgraded injection pump and put it in there too. nothin like addin right at 300 extra hp for only a lil down time. and some big cash
Old 07-26-2006, 08:08 AM
X-running's Avatar
yeah its my dads truck and the money aint an issue so it will come out with a little extra for sure.
Old 07-26-2006, 01:27 PM
Seagraves#85's Avatar
Crack the injection lines and crank the engine see if fuel is getting to the injectors. If so, it might just have air in the fuel system. There is also probably some sort of "lift pump" that delivers fuel from the tank to the injection pump see if that is working. I know that chevys have a lift pump relay that ALWAYS goes out. Just pray that the Injection pump didnt go out.
Goodluck!
Old 07-26-2006, 01:30 PM
Goodluck!
That wont work if you're injection pump has failed.. The pump will still pump enough fuel to fool you into thinking its still working, but not enough to make the truck run..
Code P0216 = BAD
Old 07-28-2006, 11:29 PM
WeeWolf's Avatar
sure it didn't run out of diesel. common prob on the dodge the damn sending units going stupid.
Old 07-29-2006, 02:19 AM
Code P0216 = BAD
NOT TRUE! The lift pump only delivers fuel to the injection pump. IF the injection pump is bad fuel will not go through it!!
